mesh generation
Posted 2025年4月13日 GMT+8 11:20MeshVersion 6.31 Reply
Hello, I encountered some technical issues while conducting simulation calculations using the electromagnetic module and would like to consult you. Currently, I am using the user-controlled mesh generation method. However, when the calculation reaches approximately 70%, the calculation speed significantly slows down, and the convergence curve becomes a horizontal straight line, failing to meet the convergence criteria. Due to the large scale of the model, if I were to switch to the physics-controlled mesh, it would result in an excessively high memory requirement, exceeding the capacity of the current computer configuration. I would like to ask if you have any suggestions for optimizing the mesh generation settings in this situation. Thank you very much for your guidance!
