Robert Koslover
Antennas, Waveguides, Electromagnetics
1 year ago
2025年6月3日 GMT+8 05:18
Updated:
1 year ago
2025年6月3日 GMT+8 05:22
Comsol Multiphysics is all about "multiphysics." So the quick and short answer is that youalmost certainly cando that! Now, whether youshouldtry to do it, whether or notyou will include all the relevant physics, orif it will work well, orif it is easy to do, andwhat is the best way to do itare allvery differentquestions! Since I haven't tried to do anything like this, I'll leave all those good and important but unasked questions to others here, to address. Good luck!
Comsol Multiphysics is all about "multiphysics." So the quick and short answer is that you *almost certainly can* do that! Now, whether you *should* try to do it, whether or not *you will include all the relevant physics*, or *if it will work well*, or *if it is easy to do*, and *what is the best way to do it* are all *very different* questions! Since I haven't tried to do anything like this, I'll leave all those good and important but unasked questions to others here, to address. Good luck!
1 year ago
2025年6月3日 GMT+8 18:58
Thanks! I have tried in a simple way, just adding those interfaces, exciting my coil from the mf interface, and seeing if it results in something in the mfh side, but have not succeeded. Maybe it needs some type of linking/coupling that I am missing.
>Comsol Multiphysics is all about "multiphysics." So the quick and short answer is that you *almost certainly can* do that! Now, whether you *should* try to do it, whether or not *you will include all the relevant physics*, or *if it will work well*, or *if it is easy to do*, and *what is the best way to do it* are all *very different* questions! Since I haven't tried to do anything like this, I'll leave all those good and important but unasked questions to others here, to address. Good luck! Thanks! I have tried in a simple way, just adding those interfaces, exciting my coil from the mf interface, and seeing if it results in something in the mfh side, but have not succeeded. Maybe it needs some type of linking/coupling that I am missing.
1 year ago
2025年6月4日 GMT+8 01:20
A rough guide to building your own coupling:
- Put both physics nder the same study.
- Use quantities from physics1 in physics2 (and vice versa, if you are coupling both ways). This may require some thinking/experimentation to get the variable names right.
- Think carefully about whether you want segregated or fully coupled solutions.
- Be prepared to deal with convergence problems.
With a bit of searching you may be able to find some examples.
As Robert says, just because you can set it up doesn't mean that it physically makes sense.
A rough guide to building your own coupling: 1. Put both physics nder the same study. 2. Use quantities from physics1 in physics2 (and vice versa, if you are coupling both ways). This may require some thinking/experimentation to get the variable names right. 3. Think carefully about whether you want segregated or fully coupled solutions. 4. Be prepared to deal with convergence problems. With a bit of searching you may be able to find some examples. As Robert says, just because you can set it up doesn't mean that it physically makes sense.
1 year ago
2025年6月4日 GMT+8 03:50
Thanks for the tips!!
I will indeed experiment, and do more research. Do you also have any tips on how i should the coil (in my case represented as a homogeneous bulk of tapes) with current, in the Magnetic Fields Formulation, mfh? And if it is also possible to link it with an electric circuit physics, as it is on the mf physics side?
>A rough guide to building your own coupling: > >1. Put both physics nder the same study. >2. Use quantities from physics1 in physics2 (and vice versa, if you are coupling both ways). This may require some thinking/experimentation to get the variable names right. >3. Think carefully about whether you want segregated or fully coupled solutions. >4. Be prepared to deal with convergence problems. > >With a bit of searching you may be able to find some examples. > >As Robert says, just because you can set it up doesn't mean that it physically makes sense. Thanks for the tips!! I will indeed experiment, and do more research. Do you also have any tips on how i should the coil (in my case represented as a homogeneous bulk of tapes) with current, in the Magnetic Fields Formulation, mfh? And if it is also possible to link it with an electric circuit physics, as it is on the mf physics side?
