heat and moisture coupled simulation of PCM walls
Hi everyone,
I'm currently working on simulating the coupled heat and moisture transfer in walls containing Phase Change Materials (PCM) using COMSOL. My main focus is to investigate how the latent heat from PCM affects temperature and moisture distribution within the wall structure during phase change.
I'm reaching out to ask if anyone has experience or resources related to:
Modeling PCM walls with coupled heat and moisture transfer in COMSOL.
Properly defining PCM properties (such as phase-change temperature range, latent heat, phase-change functions) and moisture-related parameters.
Reliable COMSOL examples or case studies specifically related to PCM and moisture coupling.
Any experiences, example models, or relevant literature would be greatly appreciated!
Thank you very much for your help and suggestions!
0 Replies Last Post 2025年6月21日 GMT+8 19:59
Hello Lufang Chen
