plasticity material properties
Hi ,
i try to solve one structural mechanics problem. In my case, i want to give yield stress level and isotropic tangent modulus properties to my model.i found one similar tutorial (snap hook) in comsol. they used yield stress level and isotropic tangent modulus.they used isotropic tangent modulus as constant value.but they used following equation as yield stress to the model.
S_yield_hook*(1+1e3*flc2hs(1-X/0.0025[m],0.25))
S_yield_hook - is yield stress of hook material
But i could not understand the below term
can anybody help me??
2 Replies Last Post 2013年3月7日 GMT+1 16:41
Posted: 1 decade ago 2013年3月7日 GMT+1 16:24
In the modelling instructions (page 8) this is described as
"The increase in the yield stress near the hook tip and thus near the contact surface
will help to avoid spurious plastic deformations that might occur due to the
computational errors during iterations in the contact force calculations."
Henrik
Hi, In the modelling instructions (page 8) this is described as "The increase in the yield stress near the hook tip and thus near the contact surface will help to avoid spurious plastic deformations that might occur due to the computational errors during iterations in the contact force calculations." Regards, Henrik
Posted: 1 decade ago 2013年3月7日 GMT+1 16:41
If your question was about the meaning of the expression, here is a description based on the COMSOL documentation: “flc2hs is a smoothed Heaviside function with a continuous second derivative without overshoot”. The expression used increases the yield stress by a factor of 1000 for X less than 2.5[mm] and does it using a smooth transition. It’s done for the reason Henrik described above.
Nagi Elabbasi
Veryst Engineering
If your question was about the meaning of the expression, here is a description based on the COMSOL documentation: “flc2hs is a smoothed Heaviside function with a continuous second derivative without overshoot”. The expression used increases the yield stress by a factor of 1000 for X less than 2.5[mm] and does it using a smooth transition. It’s done for the reason Henrik described above. Nagi Elabbasi Veryst Engineering
