Josh Thomas
Certified Consultant
2013年3月12日 GMT+1 15:46
Dimitrios-
Just an initial thought. How do you know it is necessarily a problem with meshing?
From what you've mentioned, I'd guess the physics (ie the higher velocity) is causing the convergence difficulty. Perhaps this could be corrected by tweaking the mesh, but not necessarily. Maybe you need to tweak something else. Maybe the material model? Maybe the physics set-up? Maybe the solver set-up?
Also, if you want to attach your model, first delete any solutions and meshes. In the file menu click Edit>Clear Meshes and Edit>Clear Solutions. Then, save. You should be able to attach the model in this case.
Josh Thomas
AltaSim Technologies
Dimitrios-
Josh Thomas
2013年3月13日 GMT+1 09:35
Dear Mr. Thomas,
thank you very much for the help! I noticed for higher Young Modulus values, it works fine for higher velocities, but on the other hand how can I change the physics's or the solver's set up? I am not pretty sure that I understand completely!
I also managed to attach the file, so you can have a better look!
I am looking forward a positive feedback and thank you again beforehand!
Best regards
Dimitrios
Dear Mr. Thomas,
Best regards
Dimitrios
Josh Thomas
2013年3月13日 GMT+1 15:21
Dimitrios-
My point was that non-convergence can be caused by a number of issues. You shouldn't assume that the problem is with the mesh unless you know for sure. Otherwise you may be missing the real issue.
It makes sense that model changes that result in more deformation of the solid in the physical system are going to give the solver more difficulty (ie lower modulus, higher fluid velocity, etc). The less deformation there is the more you are approaching a simple fluid flow problem which would be easier to solve.
If you haven't gone through the Model Library problems for FSI, I would highly recommend studying those examples. There is some good information on recommended discretization settings based on the Reynolds number of your flow that may apply to your issue. I'm not sure, but regardless the practice problems teach a lot.
I'm not an expert in FSI. Maybe someone else could comment on the specifics of how you might tweak this type of model to obtain convergence for high deformation problems.
FYI - The model you attached converges nicely to a solution with E = 1000[Pa] and vel=40.33[cm/s]. How low did you want to go with the modulus? How high did you want to go with the flow velocity? That information would be helpful if you'd like someone to comment on getting convergence for the more extreme case.
Regards-
Josh
Dimitrios-
Regards-
Josh
