electrical potentials
I´m analyzing the distribution of electrical potentials through different geometries with varying conductivities. An active electrode is firing with 1V under quasi-static conditions. To analyse the behaviour I modeled a big sphere which also contains the ground electrode and encloses the 'structure of interest'.
Now I want to manually define that the electrical potential on the big sphere should be 0, or how can I define Ve in a certain distance??
Hope someone can help!
Best, Manfred
2 Replies Last Post 2013年4月30日 GMT+2 10:19
Posted: 1 decade ago 2013年4月24日 GMT+2 21:04
Manfred,
you can apply a ground or electric potential BC to the sphere. It is unclear what you mean with 'Ve in a certain distance'?
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Manfred, you can apply a ground or electric potential BC to the sphere. It is unclear what you mean with 'Ve in a certain distance'? Cheers Edgar -- Edgar J. Kaiser http://www.emphys.com
Posted: 1 decade ago 2013年4月30日 GMT+2 10:19
Thanks a lot Edgar,
I simply applied the ground potential on the spheric wall. However, a new question came up:
I changed the sphere to a cuboid setting it as ground. Is it possible in COMSOL to virtually prolong one side surface to infinite setting the potential to 0?
Cheers, Manfred
Thanks a lot Edgar, I simply applied the ground potential on the spheric wall. However, a new question came up: I changed the sphere to a cuboid setting it as ground. Is it possible in COMSOL to virtually prolong one side surface to infinite setting the potential to 0? Cheers, Manfred
