Parallel evaluation of expressions in Global Evaluation
Posted 2025年8月21日 GMT+2 16:28 Heat Transfer, Cluster & Cloud Computing, Results & Visualization Version 6.3 5 Replies
Is it possible for Expressions in a Results->Derived Values->Global Evaluation node to all be computed in parallel?
I'm running view factor calculations, which require surface integrations and the evaluation of the rad.radopu function. The stationary solver (for a Surface-To-Surface Radiation problem) takes only 2 and a half minutes, while the view factor calculations take up to two hours... It seems that the evaluations are performed using only one core of my CPU.
For reference, my setup is similar to this COMSOL tutorial: https://www.comsol.com/model/view-factor-computation-20701. except that I define the surface areas and the view factors in a Variables node.
Hi Breno,
I am frequently having similar issues with complex post processing. Defining variables doesn't help because they get evaluated again when called in post processing. One workaround can be to define global state variables and assign the variables to them. State variables are stored in the solution and are available without reevaluation. States do not carry a unit and you must take care of the units by yourself.
Expensive expressions are obviously calculated much faster within the solver code than in post processing code.
Cheers Edgar
emPhys Physical Technology
www.emphys.com
Hello Edgar,
I like the idea. Though, after trying to implement it, after about 3 hours of solution, it stopped with an error, where apparently a variable was not defined (?). This seems difficult to debug. I'd need to start small with, e.g. that view factor tutorial. If you use state variables, COMSOL has to "compile" that in the equations, right? Or maybe I just set them up wrong...
I used "Boundary" geometric entities for my state variables, because they have to be evaluated as boundary surface integrations, but also set an order of 0, since they are scalars. I'm not sure if this is correct. Additionally, I set "Update: Only Initialization". Maybe there's a simplification that can be done in the Study/Solver node to improve performance?
Anyway, in the end I "solved" my problem by using normal variables in one file, running the problem, saving the file with the results, then copying and pasting this file multiple times. Open each of these files, and finally Evaluate different sets of expressions in each of them, in parallel. Definitely far from a pretty solution, but it works.
Cheers, Breno
Hi Breno,
I understood that you are calculating integrals and the integral is a global value that doesn't need to be tied to a geometric entity. I am only using global states.
Cheers Edgar
www.emphys.com
Hello Breno,
There can be different ways of doing this that can be more efficient, yes. It does also though raise the question as to why you want to compute all of these terms? That is, once you have the terms of the view factor matrix, what do you plan to do with them? I realize that this may be an involved question specific to your workflow, so if you wish to open a support case we can also discuss this more privately.
Best, Walter Frei, PhD COMSOL Support
Hi Walter,
good to see you kicking in. In some cases there is no way around doing complex operations in the data, such as integrals and averages. In such cases the postprocessing can be more costly than the solution. I successfully worked around in some cases by using the global states.
Can you suggest other more efficient ways?
Thank you, Edgar
www.emphys.com
Basic Rules
- Flaming: Do not post any messages that harass, insult, belittle, threaten, or flame another member or guest. Debates are fine, but argue with the point, not the person.
- Trolling: Do not post with the purpose of starting a dispute. Note that a person disagreeing with your opinion is not considered trolling; keep it civil, even if you are sure that the other person is wrong. Anything seen as trolling will result in you being banned.
- Spamming: Posts without content or containing nonsense waste space and everyone's time. Spam will be removed from the forum.
- Offensive Posts, Links or Images: Do not use profanity, racial, ethnic, religious, or other slurs or any other offensive material.
- Advertising: Posting of advertisements for products or services, links to auctions, affiliate links, links to promote websites, and so forth is not allowed.
- Disclosure of Personal Information: Do not disclose any other member's email, real name, address, phone number, IP address, or other personal information. This includes posting contents of emails and private messages without the sender's consent. Do not bring personal disputes into the forums. Bans and warnings issued to other users are considered personal information.
- Misleading Titles: The subject line of the post should be as informative as possible about the content of the post. This also reduces the amount of duplicate posts.
- Thread Hijacking: Taking a thread off-topic to pursue one's own agenda is not permitted.
- Piracy: Do not upload, post, email, transmit, or otherwise make available any content that infringes upon any patent, trademark, trade secret, copyright, or other proprietary rights ("Rights") of any party. This includes COMSOL model files created by a forged or illegitimate license.
- Honesty: Users must provide truthful information in creating their COMSOL Access account.
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- KNOWLEDGE BASE COMSOL and Multithreading
- KNOWLEDGE BASE Wrong number of DOFs in initial value
- FORUM lazy evaluation in expressions
- BLOG Different Ways to Count Particles in COMSOL Multiphysics
- FORUM Global evaluation
