Edgar J. Kaiser
Certified Consultant
1 year ago
2025年10月2日 GMT+8 03:01
Margarida,
a cut line dataset and a line plot using it is what you want.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Margarida, a cut line dataset and a line plot using it is what you want. Cheers Edgar
1 year ago
2025年10月7日 GMT+8 00:32
Thank you, Edgar. A cut line 2D or 3D? I tried to use a cut line 3D but using 2 points but I couldn't figure out right z-coordinate of those two points (my thin layer is in the plane xy).
Edgar J. Kaiser
1 year ago
2025年10月7日 GMT+8 14:21
Updated:
1 year ago
2025年10月7日 GMT+8 17:39
If the layer is in the xy plane, then z should be 0?
If the thin layer is implemented as a boundary you may see a temperature discontinuity. In this case you can use the up() and down() operators to see the temperatures on each side of the boundary.
Edgar J. Kaiser
www.emphys.com
If the layer is in the xy plane, then z should be 0? If the thin layer is implemented as a boundary you may see a temperature discontinuity. In this case you can use the up() and down() operators to see the temperatures on each side of the boundary.
1 year ago
2025年10月7日 GMT+8 22:01
The layer is a xy plane at a particular z=z0. The layer has thickness but there is no z-coordinate associated with it since it was defined as layered material. If I use the cut line 3D, I can choose the layered material that I previously selected as one dataset, I choose the x and y coordinates accordingly to the line I want but I could not find the right z to use. I tried the z0, zero (as you suggested ) and other options but I could not find the right z choice. Have you got other suggestions?
Thank you.
The layer is a xy plane at a particular z=z0. The layer has thickness but there is no z-coordinate associated with it since it was defined as layered material. If I use the cut line 3D, I can choose the layered material that I previously selected as one dataset, I choose the x and y coordinates accordingly to the line I want but I could not find the right z to use. I tried the z0, zero (as you suggested ) and other options but I could not find the right z choice. Have you got other suggestions? Thank you.
Robert Koslover
Antennas, Waveguides, Electromagnetics
1 year ago
2025年10月9日 GMT+8 22:08
I suggest that you post your .mph file to the forum.
