Use solution of one study as initial particle position for another without exporting
Hello there,
I am currently working with the Mathematical Particle Tracing module, although this question extends to at least the Charged Particle Tracing module.
Is it possible to use the final particle positions from one study as initial positions in another study without using the "Release from Data File" function?
I have an assembly split in two because one features rotating parts and uses the Rotating Frame domain while the other half does not. I will have to run this simulation for different values, maybe with a parametric sweep, so having the workflow a bit more streamlined would be a great time saver.
Thank you all in advance.
1 Reply Last Post 2025年11月7日 GMT+8 08:05
Daniel Smith Certified Consultant
Posted: 12 months ago 2025年11月7日 GMT+8 08:05
Updated: 12 months ago 2025年11月7日 GMT+8 08:08
Hi David -- yes this is possible! There are a few key steps you need to do: * Make sure "Store particle status data" is checked in the Physics Interface properties. * Run your first study (std1/sol1) as normal, in the attached example the time runs from range(0,0.1,1). * In your second study, set the "Initial values of variables solved for" to "sol1"andmake sure the output time arraybeginsat the last time from sol1, 1 second in the attached case (V6.3). The output range in my example is: range(1,0.1,2). * You can optionally use a third study to combine the solutions into a single one, for easier postprocessing.
It would be nice to have a dedicated release node from previous studies which could be linked to a Particle Counter feature or filter particles by size etc.
Daniel Smith
Founder
PhysAI, LLC
Newport, RI 02840
Website: www.phys2ai.com
LinkedIn: www.linkedin.com/in/daniel-smith-phys2ai
Hi David -- yes this is possible! There are a few key steps you need to do: * Make sure "Store particle status data" is checked in the Physics Interface properties. * Run your first study (std1/sol1) as normal, in the attached example the time runs from range(0,0.1,1). * In your second study, set the "Initial values of variables solved for" to "sol1" **and** make sure the output time array **begins** at the last time from sol1, 1 second in the attached case (V6.3). The output range in my example is: range(1,0.1,2). * You can optionally use a third study to combine the solutions into a single one, for easier postprocessing. It would be nice to have a dedicated release node from previous studies which could be linked to a Particle Counter feature or filter particles by size etc. Daniel Smith Founder PhysAI, LLC Newport, RI 02840
