2013年5月24日 GMT+2 11:32
I am not sure it could work, it's just ani idea, since i used always temperature as output, not input, except in boundary conditons, but have you tried to set as initial conditions the temperature in your heat source setting a really high heat capacity in the heat source region?
For small transients could be a way for emulate a constant heat source.
2013年5月27日 GMT+2 11:02
thank you for your answer.
But I do not really understand what you mean. Maybe the idea is to choose a high heat capacity in order to get similar values of Q and T? I hoped for an easier way to just use the temperature. But I will think it over.
Sandra
Sandra
Edgar J. Kaiser
Certified Consultant
2013年5月27日 GMT+2 11:11
Sandra,
if I understand you correctly it is easy. Use a temperature boundary condition and assign your temperature function to it.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Sandra,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
2013年5月27日 GMT+2 11:26
Hi Edgar,
at first I tried it with the temperature boundary condition like you suggested. But I have a 3 dimensional temperature distribution in an 3D-area and not only on a boundary. I do not only want to set a temperature distribution on the surface of e.g. an ellipsoid but there should also be a temperature value for every point inside of it.
Correct me if I'm wrong but I don't think that it is possible to use the temperature boundary condition for this purpose.
Sandra
Hi Edgar,
Sandra
Edgar J. Kaiser
2013年5月27日 GMT+2 13:47
Sandra,
I would say that the inside of the domain doesn't contribute to the model if it just remains at a fixed temperature. Only the boundary interacts with the 'variable' part of the model.
But I may still not completely understand what you are after exactly.
Edgar J. Kaiser
www.emphys.com
Sandra,
Edgar J. Kaiser
2013年5月27日 GMT+2 15:06
Hi Edgar,
you're right, usually it would be like this. I forgot to mention that I want to have this temperature contribution in every point because I want a laminar flow to go through this area. So I don't want to define a solid with a temperature on its surface but an area with the same properties like the flowing fluid.
The reason for this is that later I want to simulate a plasma with a fluid flow. But as a first step and since I got the measured temperature profile of the plasma my idea was to just set up an area with this temperatures to find out how the heat would affect the fluid flow.
Sandra
Hi Edgar,
Sandra
Edgar J. Kaiser
2013年5月27日 GMT+2 15:31
Well, then you might try to do it Francesco's way. Your attempt is a bit 'unphysical' because T is the dependent variable.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
