How to extract data from Layered Shell dataset to matlab
The mpheval and mphinterp functions fail to extract localized variables (such as r_llmat1_xdim) when querying standard evaluation datasets directly in memory. I need help on how to export this data into MATLAB. lshl1_eval = mpheval(model, {'T'}, 'dataset', 'lshl1'); 错误使用 mpheval mpheval (0): Java exception occurred: Exception: com.comsol.util.exceptions.FlException: 数据集类型无效。 Messages: 数据集类型无效。 - 标记: lshl1
lshl1_eval = mpheval(model, {'T','r','r_llmat1_xdim'}, 'dataset', 'dset1', 'selection', 3, 'edim', 1);
错误使用 mpheval mpheval (0): Java exception occurred: Exception: com.comsol.util.exceptions.FlException: 无法计算表达式。 Messages: 无法计算表达式。
未定义变量。 - 变量: r_llmat1_xdim - 几何: geom1 - 边界: 3 无法计算表达式。 - 表达式: 1000*r_llmat1_xdim - 特征: 计算
2 Replies Last Post 2026年9月2日 GMT+8 14:46
Posted: 2 months ago 2026年9月1日 GMT+8 19:17
Updated: 2 months ago 2026年9月1日 GMT+8 20:36
Hi 浩
mpheval doesn't work for extra dimensions dataset.
This should work:
dset1_eval = mpheval(model, {'T' 'r' 'z'},'dataset','dset1')
and you can add more properties to refine the extraction:
dset1_eval = mpheval(model, {'T' 'r' 'z'},'dataset','dset1','edim',1,'selection',4)
For the xtra dimensions you can use mphinterp:
[lT,lr,lrx]=mphinterp(model, {'T' 'r' 'r_llmat1_xdim'},'dataset','lshl1');
I hope this helps. If not, then please write again.
Lars Gregersen
Comsol Denmark
Hi 浩 mpheval doesn't work for extra dimensions dataset. This should work: dset1_eval = mpheval(model, {'T' 'r' 'z'},'dataset','dset1') and you can add more properties to refine the extraction: dset1_eval = mpheval(model, {'T' 'r' 'z'},'dataset','dset1','edim',1,'selection',4) For the xtra dimensions you can use mphinterp: [lT,lr,lrx]=mphinterp(model, {'T' 'r' 'r_llmat1_xdim'},'dataset','lshl1'); I hope this helps. If not, then please write again.
Posted: 2 months ago 2026年9月2日 GMT+8 14:46
It worked! Thank you so much; this problem had been bothering me for a long time.
