Using material properties for parameters, variables, functions
Posted 2026年10月9日 GMT+8 17:11Geometry, Materials, Modeling WorkflowVersion 6.23 Replies
I use a 2D model with AC/DC module and Magnetic Field interface. I would like to use some material properties to define the geometry, clearly I wish to use the skin depth to define the dimensions of a coil. What I usually do is copy the material property (here copper) in the parameters of Global Definition so I can also define delta = 1/sqrt(pi * f * mu * sigma). Is there a way to get mu and sigma directly from the material without having to create some fixed parameters ? I am open to any solutions that allow using delta in the geometry.
Thank you :)
Sarah
comp1.mat1.def.mur_iso or just mat1.def.mur_iso and comp1.mat1.def.sigma_iso or just mat1.def.sigma_iso
Assuming mat number is 1, of course.
Try it out.
-------------------René Christensen, PhD
Acculution ApS
www.acculution.com
info@acculution.com
Hi René,
Thanks for your reply. I've tried it in the the Global Parameters but it does not work.
Sarah
Maybe upload the file then
Acculution ApS
www.acculution.com
info@acculution.com
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- FORUMParameters from material properties
- FORUMNdFeB material properties
- BLOGHow to Use Interpolated Material Data to Model Irregular Geometries
- BLOGCombining COMSOL Multiphysics® and MATLAB®
- KNOWLEDGE BASEHow can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling?
