EMAT webinar example reproduction
Posted 2026年10月10日 GMT+8 03:44Studies & Solvers, Modeling Workflow, Physics Interfaces2 Replies
Hi everyone,
I am trying to reproduce the electromagnetic acoustic transducer example presented in this webinar : https://www.comsol.com/video/modeling-nondestructive-testing-methods-in-comsol-multiphysics I do not have access to the comsol file so I have reproduced the file from the video. The results are not adequate and I do not really know what is causing that : the solid mechanics quantities such as displacement are 0 everywhere. I am not used to multiphysics problems in comsol.
I have attached my file if needed.
Sarah
The problem is that your bias magnet isn't magnetic. Try changing the Magnetization Model to Magnetization and set a nonzero magnetization value in the z direction. (There may be better ways to specify this but I don't know EMATs well enough to say).
Hi David,
Thank you very much, that was exactly the problem ! I clearly needed an outside perspective ;) As I was trying to reproduce exactly the tutorial, I followed this way but I also tried using the magnet feature of Magnetic Fields. It works if you disable the magnet feature when computing the frequency domain step.
Sarah
Basic Rules
Posting Guidelines
- Write in English.
Disclaimer
Suggested Content
- KNOWLEDGE BASERunning parametric sweeps, batch sweeps, and cluster sweeps from the command line
- BLOGModeling the Spread of COVID-19 with COMSOL Multiphysics®
- KNOWLEDGE BASEError: Failed to Find a Solution. Returned Solution is Not Converged
- FORUMAbout EMAT
- KNOWLEDGE BASEWarning: New Constraint Force Nodes Detected
