How to Select the Appropriate Materials from the COMSOL Material Library for Photonics and Liquid Crystal Simulations at 1550 nm?
Dear COMSOL Community,
I am currently pursuing my Ph.D. research in the field of Photonics and Liquid Crystal (LC)-based devices using COMSOL Multiphysics 6.4.
For my simulations, I need to use the following materials:
  1. Silicon (Si)
  2. Silicon Dioxide (SiO₂)
  3. Gold (Au)
  4. E7 Liquid Crystal
  5. Silicon Nitride (Si₃N₄) and so on
My operating wavelength is 1550 nm.
When I use the Add Material option in COMSOL Multiphysics 6.4, I find multiple entries with the same or similar material names. I am unsure which specific material entry I should select for my photonics simulations.
I would appreciate guidance on the following questions:
When multiple entries are available for the same material in the COMSOL Material Library, how can I identify and select the most appropriate one?
Which material properties should I verify before selecting a material for optical simulations at 1550 nm (e.g., refractive index, extinction coefficient, relative permittivity, and wavelength-dependent properties)?
For Silicon, Silicon Dioxide, Gold, and Silicon Nitride, which material data or material models are recommended for photonics applications at 1550 nm?
For E7 liquid crystal, how can I select or define the appropriate anisotropic optical properties, particularly the ordinary refractive index (nₒ), extraordinary refractive index (nₑ), and director orientation along the X-axis or Y-axis?
If the required optical properties are not available in the built-in COMSOL Material Library, should I create custom materials using experimentally reported or literature-based optical constants?
My main objective is to ensure that I select the correct material properties for accurate electromagnetic wave propagation and photonic device simulations at 1550 nm.
I would be grateful for any suggestions, recommendations, or practical examples from experienced COMSOL users.
Thank you.
1 Reply Last Post 2026年11月17日 GMT+8 18:37
Diotima University of Manchester/Material Science
Posted: 8 hours ago 2026年11月17日 GMT+8 18:37
Dear Rajasekhar,
In my opinion, you could build the entire physics first, and create an blank material so you know what parameter is needed for your model. After this, I think you can either find appropriate material by searching through literature, or just simply pick the material that has the closest material property to your experiment or working condition set up. Hopefully my answer helps.
Yuyang Zhang
Superiora de inferioribus, inferiora de superioribus, prodigiorum operatio ex uno, quemadmodum omnia ex uno eodemque ducunt originem, una eademque consilii administratione.
Dear Rajasekhar, In my opinion, you could build the entire physics first, and create an blank material so you know what parameter is needed for your model. After this, I think you can either find appropriate material by searching through literature, or just simply pick the material that has the closest material property to your experiment or working condition set up. Hopefully my answer helps. Yuyang Zhang
