2013年6月24日 GMT+2 03:48
I am also working on three phase synchronous motor, could you share your model here so that I can see and tell you because mine is working fine.
Madhu
Madhu
2013年6月24日 GMT+2 13:05
Hallo Giovanna,
how do you define the domains for the force calculation? You cannot extend the force calculation
to the boundary of the indentity pair. There must be a ring of air in between.
Regards
Jens
Hallo Giovanna,
Regards
Jens
2013年6月25日 GMT+2 07:42
Hi! Thank you for your answer. If I need to compute the torque (for example cogging torque) in the middle of the air gap, do you mean I have to move the identity pair?Should I place it a bit nearer to the stator or shoul I compute the torque on another boundary nearer to the rotor??
J.
J.
9 years ago
2017年2月6日 GMT+1 10:59
Hi Giovanna
I'm running the same problem as you did. My model is also an interior mounted PMSM and no matter what initial position for the rotor is given, the average torque is always zero with an amplitude of maximum torque of the machine. I also built a simplified model: one pole model and suprisely this issue won't happen. So I am wondering have you solved this problem? Looking forward to your response.
Best regards
Zhi
Hi Giovanna
Best regards
Zhi
Maria-Sofia Pechlivanidoy
8 years ago
2017年7月8日 GMT+2 18:29
I have the same problem with the torque? Are you compute the cogging torque? Has anybody compute Arkkio torque for a PMSM? Can anyone attach his model program file?
2D or 3D or both.
Best regrards.
2D or 3D or both.
Best regrards.
