How can I simulate microwave 2.45GHz interference in nanoparticles?
Posted 2013年6月23日 GMT+2 17:40 RF & Microwave Engineering 0 Replies
Even when I try reproduce a plane wave with 12 cm wavelength in an empty space cube with a small dimension, inferior or equal to 10 micrometers the same error appears:
Failed to find a solution.
The relative error (0.37) is greater than the relative tolerance.
You will probably find this error as well if you simply decrease the dimensions of the periodic_boundary_condition model.
Hello Ricardo Mimoso
