2013年9月10日 GMT+2 14:53
I have used the function "flc2hs" for the step function. How are you trying to use it? Let us say that you wish to send a flow pulse into the chamber with the duration of Tp[s]. If the low rate is Vin
then inflow could be
Vin*(1-flc2hs(Tp-t,0.001))
The latter parameter defines the steepness of the pulse raise.
Now inflow = Vin, t < Tp and 0, t > Tp.
I wonder if this is what you asked ;)
BR
Lasse
BR
Lasse
2013年9月11日 GMT+2 17:02
Thanks for your reply Lasse! I was starting to think that no one would answer me :p
Well, frst of all I not sure what do you mean by function "flc2hs". Is that a predefined function of Comsol?
The way I was doing it was to first define a parameter "vol" with the amount of flow that I want (10e-9 m^3/s), for instance). Then I defined a step function, with values from 0 to 1, centered at 2s. After that, I created an analytic function whose expression is defined as: vol - vol*step1. I thought that this way, if I define my microfluidic inlet as a laminar flow with this function, it would control the amount of fluid that would enter the system.
I think that my approach is similar to the one you're proposing, but I really dont know waht do you mean by that function "flc2hs". Do you think that my approach is the best?
Thanks in advance,
Carlos H
Thanks in advance,
Carlos H
Thanks in advance,
Carlos H
Thanks in advance,
Carlos H
