vertices in Periodic BC
Dear all,
Could anybody explain me the real role of source and destination vertices in Periodic BC?
Does the amount of selected vertices influences only on precision or I MUST select all of vertices of a boundary each time?
Thanks in advance,
Alex
1 Reply Last Post 2010年3月17日 GMT+1 19:49
Posted: 2 decades ago 2010年3月17日 GMT+1 19:49
this determines the orientation of the mapping from one boundary to other. I.e. you would select the vertices in different orders depending on whether reflection, rotation etc is involved. Also I assume the boundaries will need to be topologically similar or perhaps identical. Otherwise I am not sure whether/how COMSOL deals with it.
I think you need to select all the vertices in the boundary - not sure if you can get away with a subset.
good luck
Ozgur
Dear all,
Thanks in advance,
Alex
this determines the orientation of the mapping from one boundary to other. I.e. you would select the vertices in different orders depending on whether reflection, rotation etc is involved. Also I assume the boundaries will need to be topologically similar or perhaps identical. Otherwise I am not sure whether/how COMSOL deals with it. I think you need to select all the vertices in the boundary - not sure if you can get away with a subset. good luck Ozgur [QUOTE] Dear all, Could anybody explain me the real role of source and destination vertices in Periodic BC? Does the amount of selected vertices influences only on precision or I MUST select all of vertices of a boundary each time? Thanks in advance, Alex [/QUOTE]
