2013年11月3日 GMT+1 16:23
I'm confused, are t on lhs and T on rhs the same variable?
Or t is time and T = T(t) is temperature as function of time?
Cheers
Cheers
2013年11月4日 GMT+1 07:40
hi Pollaci,
here
T is temperature, which is function of time as well as space
t-time
rgds
Anup
hi Pollaci,
here
t-time
rgds
Anup
2013年11月4日 GMT+1 08:56
Your create a "dode" that is physics of type
Domain ODEs and DAEs
Then in "Distributed ODE 1"
you enter :
da=1
ea=1
f= (A)*[exp{-E/RT}]
That shou do the jo
Jens
you enter :
da=1
ea=1
f= (A)*[exp{-E/RT}]
That shou do the jo
Jens
2013年11月4日 GMT+1 12:43
thanks
thanks
2013年11月4日 GMT+1 13:00
Dear Jens
I think "ea" should be zero, otherwise it will become 2nd order ODE.
rgds
Anup
Dear Jens
rgds
Anup
2013年11月4日 GMT+1 14:56
yes, that is a typo, Jens
2013年11月8日 GMT+1 14:11
I got a problem here, as i have mentioned, equation contains three variable:
1. time 't'
2. Temperature 'T'
3. Variable 'X ' which is again a function of three space coordinate and time ???
* All other parameters are constant
The temperature T is obtained after solving a "Transient heat diffusion equation in solid Physics" and is used as the input to the ODE. That means the two physics "Transient heat diffusion equation in solid Physics" AND "Distributed ODEs and DAEs(dode) Physics" should be coupled together since I need the value of T(x,y,z,t) to calculate X (x, y,z,t).
Can anyone please tell me, how to couple these two physics in COMSOL 4.2??
regards
Anup
1. time 't'
2. Temperature 'T'
regards
Anup
