post processing
Posted 2014年1月23日 GMT+1 15:36 0 Replies
In the attached model you will find under <results>-<derived values>-<point evaluation>-<votages for beamformer> a selection of voltages measured at several points. I typically export the voltages V(x) and process them as follows: output(theta)=sum(V(x)*f(x,theta)) where f(x) is a simple analytical function and theta is an independent variable. Is there a way to do this in comsol?
If so may I then inspect output(theta) to find various parameter such as max(output(theta)).
Thank you in advance for your help
-Dave
Hello David Parks
