Robert Koslover
Certified Consultant
2014年3月25日 GMT+1 02:59
There are all sorts of reasons that you might not see any change with frequency, ranging from setting up your model improperly to setting up your post-processing improperly (or even that you simply created a model geometry where the resulting field-line distribution is nearly invariant with changing dielectric constant). I recommend you post your model file to this forum so that others may look at it and tell you what they think you did wrong, if anything.
2014年3月25日 GMT+1 09:39
HI Robert
Thanks for replying.
It wont let me upload the raw file as it says its too large, nor can I upload a compressed version as it doesnt accept thefile extension.
any way to get around this?
HI Robert
Rob Boswell
COMSOL Employee
2014年3月25日 GMT+1 12:43
Hello Jonathan,
Before uploading, you can clear the solution to greatly reduce the file size. To do this, find the study tab and then select Clear Solutions.
If necessary, you can also clear the mesh to again reduce the size of the file.
I hope this helps.
Rob
Hello Jonathan,
I hope this helps.
Rob
2014年3月25日 GMT+1 21:51
Hi Rob
Thanks for the advice, I wasnt sure if I done that, would they be able to see what I have tried to do.
Nevertheless, I cleared the solution and uploaded what I've got so far.
Just as a reminder, I am trying to model the e-field lines with an ac supply of different frequencies however I dont know how to implement a frequency dependent dielectric constant for PbTiO3
Many thanks in advanced
Hi Rob
