Definite integral calculation
Hi!
let's say I want to evaluate this definite integral sin(alpha+theta)d_theta from theta=0 to 90 deg where alpha is a known number. How to do that? Alpha is different in every step of the calculation thus integration has to be performed at every step.
Best regards
Rokas
13 Replies Last Post 2016年6月13日 GMT+2 09:39
Posted: 1 decade ago 2014年3月29日 GMT+1 17:30
How is your question related to COMSOL?
Pu, ZHANG
DTU Fotonik
How is your question related to COMSOL? -- Pu, ZHANG DTU Fotonik
Posted: 1 decade ago 2014年3月29日 GMT+1 18:44
Thanks for your answer :)
I am working on time-dependent simulation where my alpha changes and the value of the integral is used in the next step. My question is related to COMSOL because the integral has to be evaluated by COMSOL as a part of the model. Hope this helps :)
Cheers
Rokas
Thanks for your answer :) I am working on time-dependent simulation where my alpha changes and the value of the integral is used in the next step. My question is related to COMSOL because the integral has to be evaluated by COMSOL as a part of the model. Hope this helps :) Cheers Rokas
Posted: 1 decade ago 2014年3月29日 GMT+1 19:29
Does integration coupling variable help?
Pu, ZHANG
DTU Fotonik
Does integration coupling variable help? -- Pu, ZHANG DTU Fotonik
Posted: 1 decade ago 2014年3月29日 GMT+1 20:28
Can you please elaborate?
Posted: 1 decade ago 2014年3月29日 GMT+1 20:33
I'm not sure about your particular case. But you can try to search in the documentation or just google it. Actually I think the first google result looks relevant: www.comsol.com/community/forums/general/thread/15392/
Pu, ZHANG
DTU Fotonik
I'm not sure about your particular case. But you can try to search in the documentation or just google it. Actually I think the first google result looks relevant: http://www.comsol.com/community/forums/general/thread/15392/ -- Pu, ZHANG DTU Fotonik
Posted: 1 decade ago 2014年3月29日 GMT+1 20:59
I don't think it is related with my thread. The thing is that I want to integrate not over a time or the coordinate. My integration should be performed independent to somewhat is happening in the model but the integration should be done at every time step. I attached a pdf of the equation I want to implement.
Posted: 1 decade ago 2014年3月29日 GMT+1 22:06
Isn't it possible to do the integration by yourself...?
Pu, ZHANG
DTU Fotonik
Isn't it possible to do the integration by yourself...? -- Pu, ZHANG DTU Fotonik
Posted: 1 decade ago 2014年3月29日 GMT+1 22:27
Yes, this integral has a simple analytic solution. You can define it as a simple function into your model.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Yes, this integral has a simple analytic solution. You can define it as a simple function into your model. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
I can do the integration by Matlab, it is not a problem but how to join my values with COMSOL simulation? In this case, my theta comes from Comsol, I do integration in Matlab and then obtain value should be submitted to Comsol and this routine should be performed every step. Is this what you meant?
Posted: 1 decade ago 2014年3月29日 GMT+1 22:29
Guys, I wrote this function as an example, unfortunately, the real function I use has no analytic solution.
Posted: 1 decade ago 2014年3月29日 GMT+1 22:31
Then you still can solve it numerically and use the interpolation option in COMSOL to define the function.
Pu, ZHANG
DTU Fotonik
Then you still can solve it numerically and use the interpolation option in COMSOL to define the function. -- Pu, ZHANG DTU Fotonik
Posted: 1 decade ago 2014年3月29日 GMT+1 22:35
I think that is a brilliant idea :)
Posted: 9 years ago 2016年6月13日 GMT+2 09:39
have you found a good way to solve the problem in comsol but not use the numerical solution?
