Manipulating the advancing front direction of the Free Mesh
Posted 2010年4月1日 GMT+2 22:54 0 Replies
The peculiar issue is that the geometry causing these inverted elements is the same along both the x- and y-axis, as I mentioned before. However, there are much more inverted elements along the x-axis oriented subdomain than the y-axis subdomain. Could this somehow be a result of how the advancing front mesh generator works? If so, could I control the direction over which it meshes to avoid these inverted elements? I have read the documentation regarding avoiding inverted elements, however I can't refine these high curvature areas because this would then cause problems with the phase field method, which needs elements of approximately the same size to work properly.
Thanks for any insights!
-Caleb
Hello Caleb DeValve
