Finding the Inductance of a Moving Spiral Coil
Hi everyone,
I am trying to simulate an out-of-plane spiral coil that expands and contracts based on the change of its temperature. The spiral coil is exposed to a radio frequency field between 10 - 100 MHz.
I used Solid Mechanics model to simulate the movement of the spiral coil.
I want to find the inductance of the spiral coil while it is expanding and contracting. So, I used Magnetic and Electric Fields model. However, I could not get any results.
Any suggestions?
M.N
1 Reply Last Post 2014年4月26日 GMT+2 09:36
Posted: 1 decade ago 2014年4月26日 GMT+2 09:36
First, I would model the coil separately. The coil models in COMSOL are made of closed loops. Perhaps it is is sufficient for a first approach to use the two dimensional "single turn" model in the "magnetic fields" interface (activate the "coil group" Box to connect the windings).
As a next step I would calculate the 3dim-model of the coil. This is much more difficult. First you have to model the connectors. Either there are wires that lead to the model boundary or the two wires meet at a gap (Lumped port). A further difficulty is the mesh. If the wires are close together, the mesh will become very fine.
Incidentally, there are some tutorials about coils. To get a targeted help, you have to describe the problem more accurate or attach a model.
Best regards
Ueli
Hi, First, I would model the coil separately. The coil models in COMSOL are made of closed loops. Perhaps it is is sufficient for a first approach to use the two dimensional "single turn" model in the "magnetic fields" interface (activate the "coil group" Box to connect the windings). As a next step I would calculate the 3dim-model of the coil. This is much more difficult. First you have to model the connectors. Either there are wires that lead to the model boundary or the two wires meet at a gap (Lumped port). A further difficulty is the mesh. If the wires are close together, the mesh will become very fine. Incidentally, there are some tutorials about coils. To get a targeted help, you have to describe the problem more accurate or attach a model. Best regards Ueli
