contact problem with coupled structural and thermal multiphysics
I am trying to simulate a 3D problem which involves structural and thermal multiphysics. I would like to create 2 concentric cylinders which the inner cylinder expands more than the outer cylinder when heated. Right now if I do not specify the contact pair, the inner cylinder will simply go into the outer cylinder after the simulation which is unreal.
If I try to include contact pair, the simulation cannot be solved and the following error message will appear:
"Error: 7220
All variables solved for must be treated in at least one segregated solver step."
I would really appreciate it if anyone has experienced this and knows how to solve it.
Thank you,
John
5 Replies Last Post 2011年4月9日 GMT+2 18:00
Posted: 2 decades ago 2010年4月16日 GMT+2 12:47
Look at the solvermanager. All variables, which have to be solved, are listed there. Just include them for the solving-process in one step of the segregated solver by opening a new step.
The problem is: Comsol can't solve contact problems time-dependent! You have to change certain settings in the model in order to use time-dependent solving. There is an example-model, you can find somewhere in the discussion forum.
Look at the solvermanager. All variables, which have to be solved, are listed there. Just include them for the solving-process in one step of the segregated solver by opening a new step. The problem is: Comsol can't solve contact problems time-dependent! You have to change certain settings in the model in order to use time-dependent solving. There is an example-model, you can find somewhere in the discussion forum.
Posted: 1 decade ago 2011年3月23日 GMT+1 04:55
Hello!
I have the same problem, too. I don't know that if you had solved the problem, could you give me same advice about the error?
My model is also coupled structual and thermal multiphysics with friction, when I use stationary slover ,the nonlinear solver has no convergence. So i tried the time-dependent solver algorithm, it occurs error 7220.
In the HELP file, it says: the solve contact problems,use the augmented Lagrangian method. I think the augmented Lagrangian method is Stationary solver, what I should do with the time-dependent solver?
Thank you in advance!
Yajuan
Hello! I have the same problem, too. I don't know that if you had solved the problem, could you give me same advice about the error? My model is also coupled structual and thermal multiphysics with friction, when I use stationary slover ,the nonlinear solver has no convergence. So i tried the time-dependent solver algorithm, it occurs error 7220. In the HELP file, it says: the solve contact problems,use the augmented Lagrangian method. I think the augmented Lagrangian method is Stationary solver, what I should do with the time-dependent solver? Thank you in advance! Yajuan
Posted: 1 decade ago 2011年3月23日 GMT+1 05:02
Hello!
I had the problem,too.
Does "Comsol can't solve contact problems time-dependent! " mean that there is no time-dependent solver for contact problem , if we try to solve the problem ,we should use the script?
About "You have to change certain settings in the model in order to use time-dependent solving." Could you please give me more details about "change certain setting"?
Yajuan
Hello! I had the problem,too. Does "Comsol can't solve contact problems time-dependent! " mean that there is no time-dependent solver for contact problem , if we try to solve the problem ,we should use the script? About "You have to change certain settings in the model in order to use time-dependent solving." Could you please give me more details about "change certain setting"? Thank you in advance! Yajuan
Posted: 1 decade ago 2011年4月9日 GMT+2 15:12
Hi everybody,
I have the same problem to, please, if someone could send a model or explain clearly the steps to make the contact problem work in time-dependent I'd be very grateful.
Thanks.
Hi everybody, I have the same problem to, please, if someone could send a model or explain clearly the steps to make the contact problem work in time-dependent I'd be very grateful. Thanks.
Posted: 1 decade ago 2011年4月9日 GMT+2 18:00
why do you need the time dependence ? to see the bouncing around of the contact ?
or is it just that you want a load that is increasing with time ?
If so use a stationary with a parameter called "t" and it's done
my model is a 4.1 (sorry I have left 3.5 behind ;)
Hi why do you need the time dependence ? to see the bouncing around of the contact ? or is it just that you want a load that is increasing with time ? If so use a stationary with a parameter called "t" and it's done my model is a 4.1 (sorry I have left 3.5 behind ;) -- Good luck Ivar
