Using Interpolation Functions under Parameters
I have tried to use an interpolation function to calculate a geometry variable under global parameters. In response to this, Comsol colored the expression in Red and it started blaming itself in the 3rd person saying, it failed to evaluate the expression.
I wonder whether or not it is allowed for the user to generate a simple look-up-table using interpolation function and then use it under global parameters?
If not, does anyody has a solution how to implement a look-up-table under global parameters?
Thanks in advance,
Onur
1 Reply Last Post 2014年7月7日 GMT+2 16:15
Posted: 1 decade ago 2014年7月7日 GMT+2 16:15
If your parameter is 'a' and you want its value to be 'int1(b)' then you can instead define 'b' as your parameter, and whereever you want to use the parameter 'a' you put instead 'int1(b)'.
