Error: 7214 No augmented components in Solcomp.
Posted 2010年4月12日 GMT+2 11:53 6 Replies
what should I do to avoid this error in mechanics module???
my model consist of 3*1 array of unit cells..
I've tried use "create pairs" tool but without success.
thanks in advance,
Alex
That one is unknown for me, are you sure you are dealing correctly with "assembly mode" and "pairs" ?
Try to follow one or a couple of the exercices
I am dealing with a structural-thermal coupling model. It has 4 subdomains,and I used assembly and creat 4 pairs.The pairs are active in both "htgh" and "smsld". In "htgh“ the continuity boundary condition is available on assembly pairs and in "smsld" the "contact and friction models" is used and I setted "static friction coefficient" as 0.2. I took the "free mesher",and solve the "htgh" with statical solver. BUT,I have the error:7214,"No augmented components in solcomp" and I don't konw the reason. And my model file is 6.23 MB, it is informed "file size error" when I tried to upload the model.
I do need your help because it is very important and urgent. And thank you very much!
And my email:liuyajuan89@gmail.com.
Detail:
Exception:
com.femlab.jni.FlNativeException: No augmented components in solcomp
Stack trace:
at auglagsolver.cpp, row 152, ()
at com.femlab.solver.FlSolver.femStatic(Native Method)
at com.femlab.solver.FemStatic.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
There is no problem when I chose "identity pair", the diference between "contact pair" and "identity pair" is the mesh. We must make the elements and points are same in the contact pair boundry ,so I duplicated the mesh from one boundry in the pair to the another,then the problem was resolved.
And good luck!
Yajuan
I am sorry, i found that the method above can't resolve the problem.
BUT, when i cleared the "the augmented lagrangian solver" click box this afternoon, the error disappeared. And maybe this is the available method.
Best wish?
Yajuan
