Failed to evaluate variable Jacobian.
What's the problem when the software tells:'Failed to evaluate variable Jacobian.' ? Thank u.
2 Replies Last Post 2014年7月25日 GMT+2 03:39
Posted: 1 decade ago 2014年7月24日 GMT+2 17:11
I think it most likely means that you haven't correctly defined a variable, or didn't give it any value at all. It should give you a name of the variable, for example: Failed to evaluate variable jacobian ht.hf1 on domain 1. In this case ht stands for "Heat transfer" and hf1 means "heat flux 1". With that you should be able to find where the problem is. The domain relates to which domain you have selected for that aspect of the physics.
Hope that helps
Matt
I think it most likely means that you haven't correctly defined a variable, or didn't give it any value at all. It should give you a name of the variable, for example: Failed to evaluate variable jacobian ht.hf1 on domain 1. In this case ht stands for "Heat transfer" and hf1 means "heat flux 1". With that you should be able to find where the problem is. The domain relates to which domain you have selected for that aspect of the physics. Hope that helps Matt
Posted: 1 decade ago 2014年7月25日 GMT+2 03:39
I am so glad when I get your reply. It helps me a lot. Hoping to communicate with you next time. Thanks a lot.
Shuai Yuan
I am so glad when I get your reply. It helps me a lot. Hoping to communicate with you next time. Thanks a lot. Shuai Yuan
