regarding level set method: evaluation/ calculation of optimum value of gamma (reinitialization factor)
hi,
would anyone of you tell me how to evaluate or calculate the value of gamma (reinitialization factor) before starting the initialization of the level set problem? does comsol has some inbuilt feature or some procedure for this? would somebody tell me some references/ papers to study about this parameter and its importance? if the initial conditions are zero velocity (in my case:- rising bubble model) how to determine the value of gamma if the domain is decreased to e-6 meter scale?
thanks in advance for your reply.
6 Replies Last Post 2016年10月31日 GMT+1 07:36
Posted: 2 decades ago 2010年4月26日 GMT+2 20:32
it is very tricky to calculate gamma, but there are some hints in the comsol doc., which are still very little to sort it out!
Regards
Naveed
Hi it is very tricky to calculate gamma, but there are some hints in the comsol doc., which are still very little to sort it out! Regards Naveed
Posted: 2 decades ago 2010年4月27日 GMT+2 08:32
thanks naved for your reply. i have already read those documentation. they only mention that the maximum velocity in the simulation to be taken as the value of gamma. how to calculate that value before hand? moreover its calculation may be affected by the choice of the value of gamma. so which value of velocity and gamma is correct, can't be said easily without doing so many simulations. it is just like hit and trial method.
if anybody knows any rule of thumb or procedure to calculate gamma, please tell.
anyways, thanks naved.
thanks naved for your reply. i have already read those documentation. they only mention that the maximum velocity in the simulation to be taken as the value of gamma. how to calculate that value before hand? moreover its calculation may be affected by the choice of the value of gamma. so which value of velocity and gamma is correct, can't be said easily without doing so many simulations. it is just like hit and trial method. if anybody knows any rule of thumb or procedure to calculate gamma, please tell. anyways, thanks naved.
Posted: 2 decades ago 2010年4月27日 GMT+2 10:37
Hi Dhiraj
You are absolutely right! I have done many simulations with just hit a trial values of gamma but still my drpolet moves down instead of going forward. I think COMSOL should provide elaborative procedure for epsilon and gamma. There is no way to spend hours on just fixing gamma and epsilon.
Regards
Naveed
Hi Dhiraj You are absolutely right! I have done many simulations with just hit a trial values of gamma but still my drpolet moves down instead of going forward. I think COMSOL should provide elaborative procedure for epsilon and gamma. There is no way to spend hours on just fixing gamma and epsilon. Regards Naveed
Posted: 2 decades ago 2010年4月27日 GMT+2 11:27
hi naveed,
i have done some experiment to evaluate gamma and i would like to share it with you. you might get benefited.
i have done the first simulation with some guess value of gamma. in the post-processing, i have selected the r or z value of velocity or velocity profile can be selected. this will display the min and max of velocity through out the domain. try to see the results at various times using different time in general menu of post-processing.
from there, after seeing the trend select some good value near to the maximum value of velocity. repeat the procedure.
hope it may help you.
hi naveed, i have done some experiment to evaluate gamma and i would like to share it with you. you might get benefited. i have done the first simulation with some guess value of gamma. in the post-processing, i have selected the r or z value of velocity or velocity profile can be selected. this will display the min and max of velocity through out the domain. try to see the results at various times using different time in general menu of post-processing. from there, after seeing the trend select some good value near to the maximum value of velocity. repeat the procedure. hope it may help you.
Posted: 2 decades ago 2010年4月27日 GMT+2 12:56
Hi Dhiraj
Do we need to re-initialize each time during this iteration? Or shall we go on with the iterative procedure without initialization again and again? Have you ever come across with "inconsient value error" during selection of gamma. By the way is there also some trick for selecting "epsilon"-as far as I know, it should be the maximum mesh size, h.
I worked with droplet movement in two-phase flow (gas-liquid). Thanks for sharing your experience.
Regards
Naveed
Hi Dhiraj Do we need to re-initialize each time during this iteration? Or shall we go on with the iterative procedure without initialization again and again? Have you ever come across with "inconsient value error" during selection of gamma. By the way is there also some trick for selecting "epsilon"-as far as I know, it should be the maximum mesh size, h. I worked with droplet movement in two-phase flow (gas-liquid). Thanks for sharing your experience. Regards Naveed
Posted: 9 years ago 2016年10月31日 GMT+1 07:36
I am working on electrowetting technique where droplet has to move from one surface to another. the droplet are taking around 20ms time to reach another surface for gamma=1 but i want that it should take atleast 40 ms. In that case, what changes should i make. should i increase or decrease the reinitialization parameter in level set. Moreover, is it possible to couple phase field and level set ?
Hi I am working on electrowetting technique where droplet has to move from one surface to another. the droplet are taking around 20ms time to reach another surface for gamma=1 but i want that it should take atleast 40 ms. In that case, what changes should i make. should i increase or decrease the reinitialization parameter in level set. Moreover, is it possible to couple phase field and level set ?
