The periodic boundary condition and PML question about COMOL 4
Hey Guys?
The first question is In COMSOL 3.5a, the periodic boundary condition can be express as u in the source and U*exp(i*k*a?in the destination, but it doesn't works in COMSOL4.
The other quesiton is the PML can be defined in Structural Moudule in COMSOL 3.5a, But it also can not works in COMSOL 4.
Anyone konws how to figure out these questions.
Best regards.
12 Replies Last Post 2014年5月7日 GMT+2 13:38
Posted: 2 decades ago 2010年5月18日 GMT+2 12:49
Hey Guys?
in an effort to make the interface more clean and easy to use,
the periodic boundary conditions in 4.0 is used for pure periodic or antiperiodic conditions. What you outline can be done with a Model Coupling, found under Definitions.
PMLs in solid mechanics will be added in the 4.0a release, available soon.
Niklas Rom, COMSOL
[QUOTE] Hey Guys? The first question is In COMSOL 3.5a, the periodic boundary condition can be express as u in the source and U*exp(i*k*a?in the destination, but it doesn't works in COMSOL4. [/QUOTE] Hi, in an effort to make the interface more clean and easy to use, the periodic boundary conditions in 4.0 is used for pure periodic or antiperiodic conditions. What you outline can be done with a Model Coupling, found under Definitions. [QUOTE] The other quesiton is the PML can be defined in Structural Moudule in COMSOL 3.5a, But it also can not works in COMSOL 4. [/QUOTE] PMLs in solid mechanics will be added in the 4.0a release, available soon. Niklas Rom, COMSOL
Posted: 2 decades ago 2010年5月18日 GMT+2 13:16
Thanks for your reply!
about the periodic boundary condition,how to use modle coupling to achieve this work, u in the source and U*exp(i*G*a) in the destination. Can you send me a simple example, I'll really appreciate it.
Thanks for your reply! about the periodic boundary condition,how to use modle coupling to achieve this work, u in the source and U*exp(i*G*a) in the destination. Can you send me a simple example, I'll really appreciate it.
Posted: 2 decades ago 2010年6月30日 GMT+2 02:17
I am new to migrant to COMSOL 4. I am also interested with this skill.
I have tried to realize it by model coupling, but I failed. I could not find somewhere to input my condition equation, for example I want to write u1=u0+4*L1.
Is there some examples to this problem.
It is not easy to understand it in new version of comsol.
Thanks a lot for your attention
Hi, I am new to migrant to COMSOL 4. I am also interested with this skill. I have tried to realize it by model coupling, but I failed. I could not find somewhere to input my condition equation, for example I want to write u1=u0+4*L1. Is there some examples to this problem. It is not easy to understand it in new version of comsol. Thanks a lot for your attention
Posted: 1 decade ago 2010年12月12日 GMT+1 03:51
I am also interested in this topic. Can anybody elaborate how I can implement arbitrary boundary condition equations?
Hi, I am also interested in this topic. Can anybody elaborate how I can implement arbitrary boundary condition equations?
Posted: 1 decade ago 2011年1月18日 GMT+1 11:32
Hi Guys,
did anyone of you have solved this already? I am also stuck with the same problem.
thanks,
kodanda
Hi Guys, did anyone of you have solved this already? I am also stuck with the same problem. thanks, kodanda
Posted: 1 decade ago 2011年7月29日 GMT+2 16:21
Anybody ever answer this as I have the same issue, which modal coupling do you use?
Posted: 1 decade ago 2011年7月30日 GMT+2 18:01
This is the response I got from COMSOL support:
We are currently working on implementing Floquet-type periodic boundary
conditions also for solid mechanics, but it is not yet certain when this
will be available. However, it is indeed possible to set up Floquet
conditions with a few extra steps. Here is how:
First you must create a linear extrusion coupling from one of the periodic
boundaries to the other. Linear extrusions are available in under the model
definitions in the Model Builder.
Then, create a pointwise constraint for each dependent variable you want to
have periodicity for. In
order to add a pointwise constraint, you must first have "advanced Physics
Interface Options" active in the "Show" menu.
A normal periodic boundary condition would have the following
expressions:
Constrain expression:
linext1(u)-u
Constraint force expression:
test(linext1(u)-u)
However, with Floquet boundary conditions, you must include a phase shift
in the expressions:
Constraint expression:
linext1(u)-u*exp(i*phase_shift)
test(linext1(u)*exp(i*phase_shift)-u)
This is the response I got from COMSOL support: We are currently working on implementing Floquet-type periodic boundary conditions also for solid mechanics, but it is not yet certain when this will be available. However, it is indeed possible to set up Floquet conditions with a few extra steps. Here is how: First you must create a linear extrusion coupling from one of the periodic boundaries to the other. Linear extrusions are available in under the model definitions in the Model Builder. Then, create a pointwise constraint for each dependent variable you want to have periodicity for. In order to add a pointwise constraint, you must first have "advanced Physics Interface Options" active in the "Show" menu. A normal periodic boundary condition would have the following expressions: Constrain expression: linext1(u)-u Constraint force expression: test(linext1(u)-u) However, with Floquet boundary conditions, you must include a phase shift in the expressions: Constraint expression: linext1(u)-u*exp(i*phase_shift) Constraint force expression: test(linext1(u)*exp(i*phase_shift)-u)
Posted: 1 decade ago 2011年9月20日 GMT+2 15:31
Yes, it works! Thanks a lot!
Posted: 1 decade ago 2012年2月29日 GMT+1 15:09
Could somebody explain me why in the constraint expr 'exp(i*phase_shift)' is multiplied with 'u' while in the constraint force expr 'linext1(u)' should be multiplied by this phase shift? Should the phase shift not be multiplied with the same variable?
see:
The answer to my question can possibly lie in the definition of this mysterious test-function, which I do not find and do therefore not understand.
Bruno
Hello, Could somebody explain me why in the constraint expr 'exp(i*phase_shift)' is multiplied with 'u' while in the constraint force expr 'linext1(u)' should be multiplied by this phase shift? Should the phase shift not be multiplied with the same variable? see: Constraint expression: linext1(u)-u*exp(i*phase_shift) Constraint force expression: test(linext1(u)*exp(i*phase_shift)-u) The answer to my question can possibly lie in the definition of this mysterious test-function, which I do not find and do therefore not understand. Bruno
Seid Mohamadali Sadat
Posted: 1 decade ago 2012年4月7日 GMT+2 19:35
I'm trying to use this in wave equation module, but the result is not changing when I apply this. can you please share a model?
Posted: 1 decade ago 2012年4月16日 GMT+2 05:44
i just deleted my post
Posted: 1 decade ago 2014年5月7日 GMT+2 13:38
May I ask that what the operator linext1 in "linext1(u)" stand for ?
