2015年2月9日 GMT+1 10:21
Attached my solution to the problem; c is the variable. I used the flux condition
-k*C0*(c/C0)^a
where k is the heterogeneous rate constant (cm/s). You must use the scaling concentration C0 = 1 mol/L in the non-linear condition, because the units do not agree otherwise. Now, (c/C0)^a is dimensionless number. In order to make the flux in mol/(cm²·s), I multiply the expression again with C0, which makes the units correct. Basically, it is just question of dividing and multiplying with 1, but you must adjust the value of k to make the physical situation coincide with your experiments.
best regards
Lasse
-k*C0*(c/C0)^a
best regards
Lasse
2015年2月9日 GMT+1 11:12
thanx sir but i am using 4.4 licensed version of comsol,so the .mph is not opening.When i tried to replace c2 by c2/C0 it is showing error telling dat C0 is unknown variable.
Regards
Regards
2015年2月9日 GMT+1 11:13
You have to define C0, a and k in the global parameters list.
2015年2月9日 GMT+1 11:43
Respected Sir,
The following is the expression i wish to enter in the flux condition of transport of dilute species module.Plz let me know as where am i going wrong as comsol is showing error.
-0.476[mol^0.5/s*m^0.5]*(c[mol/m^3]*(c2[mol/m^3])^0.5)/(1+998*c[mol/m^3])
I will be extremely thankful to you
Regards
Respected Sir,
Regards
2015年2月9日 GMT+1 11:52
Thank you sir.I will definitely try by defining them in the global parameter list
2015年2月9日 GMT+1 12:14
What is that 998 in the denominator? Water density in kg/m^3? Anyway, I would write
-k*c*(c2/C0)^a/(1+K*(c/C0))
k = 0.476[m/s] (or whatever you need)
C0 = 1[mol/l]
a = any number
K = 998 (no unit)
Now the flux has unit mol/(m²·s) since c has the unit mol/m^3.
br
Lasse
C0 = 1[mol/l]
a = any number
K = 998 (no unit)
br
Lasse
