Transport of dilute species module
Respected Sir,
I am attaching my .mph file.It is working well when a>=1.For my case a=0.5 it is showing error.
Here 'a' is the power of the concentration.
I kindly request you to help me out with this problem.
Regards
3 Replies Last Post 2015年2月10日 GMT+1 15:12
Posted: 1 decade ago 2015年2月10日 GMT+1 15:05
I just remembered that you have to write the flux BC as
-kr*c1*(c2/C0+eps)^a/(1+K*(c1/C0))
"eps" is a machine constant, floating point accuracy, a very small number, 2^-52. Look at help with "eps".
Another thing: You do need two separate nodes of "Transport of Dilutes Species", you can have both variables c and c2 in the same node, just put the number of variables 2.
I usually do so that I first calculate the laminar flow at steady-state in its own Study, i.e. disabling all the other physics; let's call this Study 1. Then I calculate the rest of the physics in another Study 2, disabling Laminar Flow, and in the menu "Values of variables not solved for" I select "Study 1, Stationary". In the Transport of Diluted Species node I choose the velocity field "spf", not user defined u and v. Now Comsol understands that I am using the velocity field of the Laminar Flow node for which Comsol gives the default identifier "spf".
I tried with a = 0.5 with no problems.
Lasse
Hi I just remembered that you have to write the flux BC as -kr*c1*(c2/C0+eps)^a/(1+K*(c1/C0)) "eps" is a machine constant, floating point accuracy, a very small number, 2^-52. Look at help with "eps". Another thing: You do need two separate nodes of "Transport of Dilutes Species", you can have both variables c and c2 in the same node, just put the number of variables 2. I usually do so that I first calculate the laminar flow at steady-state in its own Study, i.e. disabling all the other physics; let's call this Study 1. Then I calculate the rest of the physics in another Study 2, disabling Laminar Flow, and in the menu "Values of variables not solved for" I select "Study 1, Stationary". In the Transport of Diluted Species node I choose the velocity field "spf", not user defined u and v. Now Comsol understands that I am using the velocity field of the Laminar Flow node for which Comsol gives the default identifier "spf". I tried with a = 0.5 with no problems. Good luck Lasse
Posted: 1 decade ago 2015年2月10日 GMT+1 15:08
Attached my model if you have Comsol 5.
Posted: 1 decade ago 2015年2月10日 GMT+1 15:12
thanx a lot sir for guiding me..now i will try the way you told me
