probe variable problem
I defined a domain point probe (Temperature)and the model runs fine and I get a table of the temperature at specified times.
But if I try to define a variable with an expression that includes the probe variable and run the model I get an error message saying it does not recognize the probe variable. Is there some way to define an initial value for the probe variable? What am I doing wrong?
thanks for your help
David
2 Replies Last Post 2015年2月13日 GMT+1 11:04
Posted: 1 decade ago 2015年2月12日 GMT+1 10:42
What do you try to probe? Whats is the unknown variable? Is there, say, a constant parameter which is not declared before running the simulation?
Lasse
Hi What do you try to probe? Whats is the unknown variable? Is there, say, a constant parameter which is not declared before running the simulation? Lasse
Posted: 1 decade ago 2015年2月13日 GMT+1 11:04
OK thanks, I found the problem, I defined the variable in the Global variables instead of the modelvariables
