Saving only the sequence
Posted 2015年2月18日 GMT+1 09:53 7 Replies
If I make a model (geometry, physics, mesh) but do not solve it, the file size is naturally very small, 20 kB, for example. Solving it increases the size to, say, 10 MB. Fair enough, but if I then delete the solution (Data set) the file size still is 10 MB. Thus, how to get back to the original 20 kB file size, that I could send it to a colleague (or this forum) as an attachment?
BR
Lasse
I tested that with two of my recent models. One is 160 MB with solution. After clearing solutions and meshes it is 0.7 MB. The other smaller one is 16 MB with solution and 92 kB with cleared solutions and meshes.
So it is not that bad. A bit mysterious why your 10 MB model isn't shrinking by clearing the solution?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
You just deleted the data set, or is there some other operator?
Lasse
I studied the problem a bit further: Deleting the Data Set does not remove it. If I right click the Result node again, I can recover my solution. Hence, it was never gone. How is it deleted for good?
Lasse
Edgar J. Kaiser
www.emphys.com
Lasse
Besides clearing all solutions (in the study ribbon), you can also clear all meshes (in the mesh ribbon), to make the file as small as possible.
