comsol 4.0, delete column in tables.
In the same vein as the player export, the delete column contextual menu for tables does not work...
4 Replies Last Post 2010年6月19日 GMT+2 10:41
Posted: 2 decades ago 2010年6月18日 GMT+2 21:41
in my 4.0.0.937 on Win-7 64bits both do work though.
Have you installed the last patch ?
Hi in my 4.0.0.937 on Win-7 64bits both do work though. Have you installed the last patch ? Ivar
Posted: 2 decades ago 2010年6月18日 GMT+2 22:29
last patch installed. Platform macintosh.
version 4.0.0.937
last patch installed. Platform macintosh. version 4.0.0.937
Posted: 2 decades ago 2010年6月19日 GMT+2 06:32
Then you should inform "support" in ym view.
I remember that the animation before did have some problems depending on the format selected, and the OS but I believe that was back in 3.4, could be similar issues
Hi Then you should inform "support" in ym view. I remember that the animation before did have some problems depending on the format selected, and the OS but I believe that was back in 3.4, could be similar issues Good luck Ivar
Posted: 2 decades ago 2010年6月19日 GMT+2 10:41
I have done so. But i want to check here to see if someone has found some other way of performing this action.
thanks
[QUOTE] Hi Then you should inform "support" in ym view. I remember that the animation before did have some problems depending on the format selected, and the OS but I believe that was back in 3.4, could be similar issues Good luck Ivar [/QUOTE] I have done so. But i want to check here to see if someone has found some other way of performing this action. thanks
