FSI and Turbulent Flow
I am trying to use the turbulent k-epsilon model in the chemical engineering module with fluid-Structure Interactions (FSI). Since my problem is an FSI case with turbulent fluid flow, I must use turbulent model with the FSI feature. While trying to solve the problem, It gives a message
"Error: 6250
Failed to evaluate variable Jacobian.
- Variable: T_x_chns2
- Geometry: 1
- Boundaries: 16,17,42,47"
Kindly guide me if I am not selecting the modules properly or not coupling it propoerly. Kindly suggest what should I do. The file is attached for reference.
Thank you
3 Replies Last Post 2011年5月5日 GMT+2 16:54
Posted: 2 decades ago 2010年6月29日 GMT+2 22:45
Look at the boundary loads in solid mechanics module. It is written -T_x_chns2 which should read -T_x_chns I assume.
Posted: 1 decade ago 2011年3月2日 GMT+1 13:06
did you suceed in implementing FSI and Turbulent Flow? I am facing the same problem...
For the simple Navier-Stokes application mode (ns), the application variable for Total Force per Area is T_xi. In chns, there is only T available, described as Total Force per Unit Area. I therefore tried T_chns, for all 3 directions (x,y,z), but I still get the same error message.
- Variable: T_chns
Any suggestion? Thanks.
Hi, did you suceed in implementing FSI and Turbulent Flow? I am facing the same problem... For the simple Navier-Stokes application mode (ns), the application variable for Total Force per Area is T_xi. In chns, there is only T available, described as Total Force per Unit Area. I therefore tried T_chns, for all 3 directions (x,y,z), but I still get the same error message. Failed to evaluate variable - Variable: T_chns Any suggestion? Thanks.
Posted: 1 decade ago 2011年5月5日 GMT+2 16:54
Anyone had good luck to solve this problem?
