how to open model files before 3.5a with 4.0a
Posted 2010年8月22日 GMT+2 21:33 6 Replies
that I want to learn. But when I open them in 4.0a there show the error:error in opening zip file.
I think they are modeled in a earlier version ?
And how can I deal with it ?Must install a earlier version?
Today you need to get it into a v3.5a version and then saved it as a 3.5a file, and then import it into V4
comsol convertpre35a
I've never used it, and you probably have to either enter it from the command line or make an icon.
I also have the same problem. But I am confused where to type this command: comsol convertpre35a and how to run it? Is it possible to choose which file of V3.5 I want to convert and to choose the path where I want to save the converted file?
If someone knows how to do it, I would be very glad.
David
not all features are there in 4.0a, it's better in V4.1 but probably last compatible features even later. But also COMSOL has cleaned up a few things so its not 100% possible to convert everything I believe.
I systematically rebuild my models from scratch in V4, mostly by having a 3.5 or a second V4 with the translated file as example, its rather quickly done for most models, and there are new and improvesd ways to do things in V4 that were not there before.
I was incorrect in my previous post, having version 3.5a installed is required to use the conversion tool.
www.comsol.com/support/knowledgebase/1080/
How you enter the commands is somewhat platform dependent but the installation and operations guide has it documented.
Suggested Content
- FORUM how to open 4.1 file in 4.0a
- FORUM Can not open model made in versions before COMSOL 3.5a in 4.3
- BLOG How and When to Open Recovery Files in COMSOL Multiphysics®
- KNOWLEDGE BASE How to recover your work from an interrupted simulation
- KNOWLEDGE BASE Can COMSOL import topological data, meshes and images?
