How to couple multiple physics
Posted 2015年8月21日 GMT+2 17:08 RF & Microwave Engineering, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers 0 Replies
I have a big issue when I try to model harmonic generation in plasmonic nanoantennas with the RF module. But this can be a general issue when you must couple multiple physics.
I am simulating the nonlinear phenomena of Second-Harmonic Generation and Third-Harmonic Generation, therefore 3 frequencies are involved: f1, f2 and f3.
I wrote my script as it was a coupled-physics problem:
- I set Study 1 to solve the problem at the frequency f1, which is independent from the others, no problem.
- I set Study 2 to solve the problem at the frequency f2, where the field is dependent only on a variable evaluated during Study 1. No problem, I set "Values of variables not solved for" in order to get the required value from the solution calculated during Study 1.
- Finally, I set Study 3 to solve the problem at the frequency f3, which must be dependent both on the fields at f1 and f2. But in this case one "variable not solved for" should be taken from Study 1, and the other one from Study 2.
Is it possible to perform this action in some way in my script? Or maybe there is a simpler way to couple studies at different frequencies?
Thanks!
Hello Daniele Modotto
