Integrating over a portion of a 3D domain?
Posted 2015年9月14日 GMT+2 23:07 Parameters, Variables, & Functions, Results & Visualization Version 4.4 7 Replies
If it is not possible to add such a region and high accuracy is not crucial, integrate over a larger domain while using a boolean expression in your integrand.
I'll also have to look into how to add a boolean to the integrand. That's new territory for me.
Paul
Say that you want to integrate u^2 but not over the whole domain. You only want the integration where X>17 and Y<4711. Then you can integrate the expression
(X>17)*(Y<4711)*u^2
The logical expressions evaluate to either 1 or 0.
Henrik
in which way is using the boolean expression in the integrand affecting precision?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
That makes that nice and simple! Thank you.
Paul
When carrying out numerical integration by Gaussian quadrature, if you use the boolean expression approach instead of the separate domain approach you're putting yourself at the mercy of elements that sit on both sides of the boolean condition: how many of their quadrature points are on each side and what their weights are is rather unpredictable.
Example: Set up a Laplace equation model on the canonical square [0,1]x[0,1], so that the solution is u=1. Mesh it with a single rectangular element. COMSOL captures the trivial solution perfectly, of course. But compute the integral of u over [0,.6]x[0,1] using the boolean approach and you'll get ~.722 because of where the Gauss points are and of their weights. ( As a side note, if you reduce the quadrature order from the default 4 to 3, you'll get .5 because then half the Gauss points and half the weights sit on each side of the x=.6 line).
On the other hand, if you split the domain into two at x=.6, you'll get the correct solution: .6.
thanks for the explanation. So, small domains with few inner and relatively many edge (at the boolean edge) elements are more susceptible to this kind of numerical error.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Suggested Content
- FORUM Integrating an expression over discrete volumes within a domain
- KNOWLEDGE BASE Solving electromagnetic heating models with high-frequency loads
- FORUM Integrating over an arbitrary line
- BLOG Studying Stress in Threaded Pipe Fitting Designs from CAD Assemblies
- FORUM Integrating over Poynting vector
