error in evaluating variables
Greeshma Grace Paulson
I am modelling a cantilever switch.while doing study i faced with an error of failed to evaluate variables and expression.
Failed to evaluate variable.
- Variable: comp1.emi.disp
- Geometry: 1
- Boundary: 22
- Expression: 1000000*comp1.emi.disp
- Plot: surf1 (Surface)
what does it mean?
4 Replies Last Post 2015年12月2日 GMT+1 06:56
Posted: 10 years ago 2015年11月12日 GMT+1 08:29
comp1.emi.disp is the displacement (sqrt(u^2+v^2+w^2)) of the Component comp1 (the first default model) of "emi" phyiscs Electromechanics from MEMS module. If you are in 2D w=0 and in 1D both v&w are =0, and in 2D-axi v=0.
But if your domain "1" is included in the EMI physics then "disp" should be defined. However, I suspect that you are plotting a complex geometry where only part of it is using EMI then "disp" is not defined everywhere. You must then restrict your Plot or Derived Value or Definition Variable to the domains where EMI is applicable
Hi comp1.emi.disp is the displacement (sqrt(u^2+v^2+w^2)) of the Component comp1 (the first default model) of "emi" phyiscs Electromechanics from MEMS module. If you are in 2D w=0 and in 1D both v&w are =0, and in 2D-axi v=0. But if your domain "1" is included in the EMI physics then "disp" should be defined. However, I suspect that you are plotting a complex geometry where only part of it is using EMI then "disp" is not defined everywhere. You must then restrict your Plot or Derived Value or Definition Variable to the domains where EMI is applicable -- Good luck Ivar
Posted: 10 years ago 2015年11月25日 GMT+1 08:15
sir
thank you for your valuable reply. Here i am attaching my model. i couldnt follow your suggestion. i Humbly request you to help me for solving this issue
sir thank you for your valuable reply. Here i am attaching my model. i couldnt follow your suggestion. i Humbly request you to help me for solving this issue
Posted: 10 years ago 2015年11月25日 GMT+1 10:41
Since none of the domains has the 'Linear Elastic Dielectric' material model, there are no displacement degrees of freedom in your model. All domains are purely electrical.
Henrik
Hi, Since none of the domains has the 'Linear Elastic Dielectric' material model, there are no displacement degrees of freedom in your model. All domains are purely electrical. Regards, Henrik
Posted: 10 years ago 2015年12月2日 GMT+1 06:56
Thank you sir for your reply.I got the displacement.
