Scattering problems, background field
Hi!
Does anyone know how to define background filed ( in Ewfd, solve for scattered field) as an interpolated function from Comsol?
3 Replies Last Post 2016年1月28日 GMT+1 15:49
Hello Eugene Cheypesh
Posted: 10 years ago 2016年1月28日 GMT+1 14:37
Hi, Eugene!
Have you obtained a solution for this problem? I have the same.
Hi, Eugene! Have you obtained a solution for this problem? I have the same.
Posted: 10 years ago 2016年1月28日 GMT+1 14:46
Partly yes.
You should export your data to file as a table. It can be done in "Export" ->"Data". Then if you need information about field, you choose it in "Expression".
Now you have files with tables with meanings of your field. By the way, you can wary the grid.
How to use it as background field: you should interpolate ypur tables. It can be done at
Global definitions-> functions->interpolation-> download from table
And now you can use your function as background field
Hi, Partly yes. You should export your data to file as a table. It can be done in "Export" ->"Data". Then if you need information about field, you choose it in "Expression". Now you have files with tables with meanings of your field. By the way, you can wary the grid. How to use it as background field: you should interpolate ypur tables. It can be done at Global definitions-> functions->interpolation-> download from table And now you can use your function as background field
Posted: 10 years ago 2016年1月28日 GMT+1 15:49
If a field is computed by COMSOL, it's both unnecessary and not a good idea to export it out and import it back in, for many reasons.
Please contact COMSOL's support team if you need assistance with this: www.comsol.com/support . They will be able to help with the best way to handle you particular case.
If a field is computed by COMSOL, it's both unnecessary and not a good idea to export it out and import it back in, for many reasons. Please contact COMSOL's support team if you need assistance with this: http://www.comsol.com/support . They will be able to help with the best way to handle you particular case. Jeff
