Varying Boundary Conditions on Restart
Posted 2010年9月23日 GMT+2 17:120 Replies
All right, so I am very new to COMSOL and trying to start out using a model someone else built, but implementing some different BCs than they did. I am modeling heatflux on a structure in a wind tunnel. I am simply assuming a heatflux profile and trying to understand the temperature within the model as a funcion of time.
But, during the .5 second tunnel start-up, I do not know the heatflux. So, during that time I specify an ambient temperature and use a "temperature" BC and then the model reacts to the ambiet temperature. That part works.
For the next 1.5 seconds, my goal is to apply a heatflux (specified by a function) and have the model start where it left off, and react to the heatflux. So, I change the BC to "Heatflux" and specify the function for heatflux as a function of time. I then choose to restart where the "initial value" is the "current solution", and the "values of variables not solved for and linearization point" is the "current solution".
The problem is that the results show that the temperature going forward is reset to the initial conditions instead of running from the BC change over pint. Any thoughts?
Last Post 2010年9月23日 GMT+2 17:12
Hello Ted Earp
