user defined convective heat transfer coefficient for solid-liquid interface
Posted 2015年12月14日 GMT+1 09:43 Fluid & Heat, Heat Transfer & Phase Change 5 Replies
How can I give a user defined convective heat transfer coefficient, h, to COMSOL for a solid-liquid interface? The inlet temperature of the fluid and its flow rate are known.
The h value I want to enter manually is simply a constant.
The busbar tutorial in the Introduction to COMSOL Multiphysics manual, version 5.2, shows how to do this. All manuals can be reached through File>Help>Documentation.
I know the heat transfer coefficient from experimental data that I trust and do not want to go for conjugate HT, lam. flow since my model is computationally heavy and I want to make less important parts as simple as I can.
Are you saying that you can assume an expression for the fluid's temperature at the interface with the solid, T_ext? If so, you can type that expression in the GUI.
There is a flow of liquid with known flow rate and known inlet temperature, but I do not know how the temperature of the fluid will change as it passes through a channel in a solid.
I want to find a way to give the inlet temperature of the liquid, its flow rate, and the convective heat transfer coefficient for the liquid-solid interface (which is a constant value) to COMSOL, and COMSOL calculate the outlet temperature of the liquid and the temperature field in the solid and the other parts which are in thermal contact with the solid.
The solid gives the heat taken from the liquid to other parts and ambient air.
The differential equation that I derive for the liquid is
m_dot*cp*dT_f/dx=-h*perimeter*(T_f - T_s)
If T_s (temperature of the solid at the interface) was constant it was easy to solve my problem in COMSOL by solving the equation analytically and writing the resulting equation in COMSOL, but now that the solid temperature is not constant I do not know how to do it.
I understand you would like to stay away from that approach, but if you want to give it a shot one way to set it up is covered on pages 110-124 of the Introduction to COMSOL Multiphysics manual, version 5.2.
Jef
Suggested Content
- KNOWLEDGE BASE Manually Setting the Scaling of Variables
- FORUM Can the convective heat transfer at the solid-liquid interface be obtained during convective heat transfer?
- FORUM A mathematical expression to determine the convective heat transfer coefficient between a solid-liquid interface
- KNOWLEDGE BASE Using Symmetries in COMSOL Multiphysics
- BLOG Modeling Natural and Forced Convection in COMSOL Multiphysics®
