artificial diffusion
Posted 2010年10月2日 GMT+2 15:53 1 Reply
I have a system of PDEs with two variables u1 and u2. I'm using PDE module. I know that I need to add artificial diffusion to both equations to converge. I add -D*u1x and -D*u2x to the flux term. D is artificial diffusion constant.
problem is that from case to case (changing initial state or injection condition) the program converges not for smaller values of D than D0 and this D0 depends on the case.
on the other hand my solution changes a little if I use relatively bigger valu of D than the minimum convergable D. but as I said this minimum varies from case to case.
Is it possible to ask comsol to add minimum convergable artificial diffusion addaptive to each grid block itself rather than I set the fix value of D?
I'm using general PDE module and transient solution in comsole 3.5a.
I really appreciate your help.
1 Reply Last Post 2010年10月3日 GMT+2 09:26
