Solving multi domain (different diffusivity) Poisson-Nerst-Planck equation
Hello all,
I am trying to solve multi domain (diffusivity is different from each region for c1, c2) Poisson-Nernst-Planck equation.
In order to do this, I am coupling electrostatic(es) module and Transport dilute species (tds) module.
In the case of dielectric constant, I can set different value by using 'from material'.
However, in the case of diffusivity, I cannot set each region different from each other.
I also tried using two (tds) module, however, I cannot converge them.
I always end up with the error 'Undefined variable.' and 'Failed to evaluate Jacobian of expression.'
Does anyone has good idea how to deal with this issue!?
2 Replies Last Post 2016年5月26日 GMT+2 20:07
Posted: 9 years ago 2016年5月26日 GMT+2 12:14
Under tds module, define another "Transport properties" item and assign the other D value there.
BR
Lasse
Under tds module, define another "Transport properties" item and assign the other D value there. BR Lasse
Posted: 9 years ago 2016年5月26日 GMT+2 20:07
Thank you!
Now it works :)
Thank you! Now it works :)
