Lagrange multiplier in axial symmetry
Hey Guys,
i am modelling a moving boundary interface (Stefan Problem), using the Lagrange multiplier T_lm from heat transfer analysis for prescribed normal mesh velocity in the deformed geometry physics.
The model is almost identical to the 2D Tin melting front example from Comsol library:
www.comsol.com/model/tin-melting-front-6234
except that I work in axial symmetry and my interface is perpendicular to the axis of symmetry.
When I solve, the Lagrange multiplier T_lm is always zero at r=0. I guess I am missing something fundamental here ? Does anyone have a hint for me ?
Thank you and Regards
______
Flanell
2 Replies Last Post 2017年4月27日 GMT+2 11:40
Hello Flanell
Posted: 9 years ago 2017年4月18日 GMT+2 07:36
Hi Flanell,
In fact, the Lagrange multiplier T_lm should be in W/m2, but for symetric problems is in W/m. you should easily just use: T_lm [W/m^2]/(rho_Si*DelH*r*pi) instead of T_lm [W/m^2]/(rho_Si*DelH). In this case the Lagrange multiplier transfer from "per radius" to "per area (Pi*r*r*)"
Hi Flanell, In fact, the Lagrange multiplier T_lm should be in W/m2, but for symetric problems is in W/m. you should easily just use: T_lm [W/m^2]/(rho_Si*DelH*r*pi) instead of T_lm [W/m^2]/(rho_Si*DelH). In this case the Lagrange multiplier transfer from "per radius" to "per area (Pi*r*r*)"
Posted: 9 years ago 2017年4月27日 GMT+2 11:40
Hi Amir,
thanks alot!
I figured it out alreday and it works like you said
Best
______
Flanell
Hi Amir, thanks alot! I figured it out alreday and it works like you said Best -- ______ Flanell
