Problem with assembly: magnetic field does not change during motion (moving mesh)
Posted 2011年1月28日 GMT+1 13:26 Low-Frequency Electromagnetics, Mesh, Results & Visualization Version 3.5a 3 Replies
Dear community,
I followed your advices in different threads, read through modeling.pdf and the tutorials, namely "generator 2D" and "generator sector dynamic".
My problem:
I have a magnetic circuit with 3 objects, one is the coil. I model a motion of the coil but at the different positions the flux in the coil does not change. The coil just "carries" the flux from the first position with it. My final goal is to simulate the induced current (density) and the changing magnetic field due to this current and eddy currents.
My model:
I start with an axial symmetry, AC/DC, quasi-statics magnetic, azimuthal induction currents. I add moving mesh (transient). The geometry consists of 2 composite objects: the inner (left) is the 1st part of the magnetic circuit, the middle is the coil with surrounding air, the outer (right) is the 2nd part of the magnetic circuit. To the coil part I apply a motion (indeed - since all parts have the same height this part moves some percent up and down then).
I created 2 pairs, both with the coil (middle) part as destination. Boundary condition of the identity boundaries is Continuity. I don't have any setup in "Options -> Identity Conditions" but I do have two Pairs each under "Physics -> Identity Pairs -> Identity Boundary Pairs" and " -> Identity Point Pairs". I don't have any integration variables.
Just according to "generator 2D" I solve the model first with setup static and then transient.
I hope you could help me with an idea what to check and maybe change.
Thanks a lot!
Clemens
My problem:
My model:
Thanks a lot!
Clemens
3 Replies Last Post 2011年3月12日 GMT+1 11:12
