Skin Friction Coefficient in the Turbulent flow over a backward-facing step.
Hi!
My name is Yerko Luppi, i live in Chile and i'm studying mechanical engineering. This is my last year.
I'm learning about CFD and i started with the 2D Backstep Model www.comsol.com/showroom/documentation/model/228/
My teacher wants validate the model by the Skin friction coefficient (using the Wilcox's graphics).
The problem is that i don't know how to get to this coefficient in comsol.
The Skin friction coefficient is www.cfd-online.com/Wiki/Skin_friction_coefficient
How can i do it?
I hope someone can help me, I'll be very grateful.
Best Regards from Chile :)
2 Replies Last Post 2012年1月10日 GMT+1 07:13
Hello Yerko Luppi
Posted: 1 decade ago 2012年1月9日 GMT+1 23:01
HI,
I read your request on cfd and skin-surface problem. I have a similar problem but no solution.
Did you solve the problem?
Dan Forsström
Polymira AB
Sweden
HI, I read your request on cfd and skin-surface problem. I have a similar problem but no solution. Did you solve the problem? Regards, Dan Forsström Polymira AB Sweden
Posted: 1 decade ago 2012年1月10日 GMT+1 07:13
Hola Chile
Well I haven't studied that part of Physics recently, I would have to dig into the books again, but there are a few things you can easily do to get some clues:
1) you can plot the local stress tensor i.e. normal and tangential to your surface, even double your solid volume by a second fluid volume slightly greater than the solid such that you get the shear forces somewhat above the no-slip contact region
2) for the standard FSI it's not that interesting, but for a sphere or cylinder, or ellipsoid, or a "wing" in a fluid flow you can use the polar plot to get a 360° view (add a polar plot, add a line graph and use atan2(y,x) as equation per line graph, then select variables like spf.K_stressx, or spf.T_stressx
3) use the data set cut line to see how these components change with separation distance from the FSI boundary
greetings from the north
Have fun Comsoling
Hola Chile Well I haven't studied that part of Physics recently, I would have to dig into the books again, but there are a few things you can easily do to get some clues: 1) you can plot the local stress tensor i.e. normal and tangential to your surface, even double your solid volume by a second fluid volume slightly greater than the solid such that you get the shear forces somewhat above the no-slip contact region 2) for the standard FSI it's not that interesting, but for a sphere or cylinder, or ellipsoid, or a "wing" in a fluid flow you can use the polar plot to get a 360° view (add a polar plot, add a line graph and use atan2(y,x) as equation per line graph, then select variables like spf.K_stressx, or spf.T_stressx 3) use the data set cut line to see how these components change with separation distance from the FSI boundary greetings from the north -- Have fun Comsoling Ivar
