Partial dissapearance of design while Meshing
Dear sir,
I was designing a 3D high volatge transmission tower using your software when a part of my structure got disapeared while meshing my design.After completing a certain portion of the design i meshed it once where it was working fine but when i meshed after designing the next part of the structure, a part of the structure was lost.It showed the same part till where i had simulated earlier.But we regained our geometry on clicking geometry , the problem comes only when we click on Mesh to obtain the results. Please look into the problem and reply as fast as possible.
Your's sincerely.
Puneet Malhotra
1 Reply Last Post 2011年4月4日 GMT+2 07:10
Posted: 1 decade ago 2011年4月4日 GMT+2 07:10
it's not easy for us to understand what is happening, as I have not observed such behavior, if you do not want to publish your model here you have support, i suppose. Anyhow I can only suggest that you use the latest version as many things have improved since the early v4.0
Hi it's not easy for us to understand what is happening, as I have not observed such behavior, if you do not want to publish your model here you have support, i suppose. Anyhow I can only suggest that you use the latest version as many things have improved since the early v4.0 -- Good luck Ivar
