How to define a boundary condition which varies within a given domain
I am trying to solve the Poisson's Equation. To simplify the problem, it is a 1-D problem, where the domain is 0 < x < 1
the Poisson's equation defined that d^2u/dx^2 = K where K = constant.
the boundary condition which I have is u(x=0) = u0
and du/dx = 0 when x = x1
While x1 is between 0 and 1 which is yet an unknown.
Is it possible to define such a system ?
Thank you.
Chin Kin
3 Replies Last Post 2011年4月8日 GMT+2 22:43
Posted: 1 decade ago 2011年4月8日 GMT+2 21:42
if I count right, I find 3 DoFs and 2 boundary conditions, hence you have an infinite number of solutions and such a system cannot be solved by COMSOL as it wants a fully defined BVP, if you decide a value for your "x1", I believe it should work.
What you can do is to scan x1 from 0 to 1 (just check that if x1==0 or x1==1 you do not have a degeneracy)
Hi if I count right, I find 3 DoFs and 2 boundary conditions, hence you have an infinite number of solutions and such a system cannot be solved by COMSOL as it wants a fully defined BVP, if you decide a value for your "x1", I believe it should work. What you can do is to scan x1 from 0 to 1 (just check that if x1==0 or x1==1 you do not have a degeneracy) -- Good luck Ivar
Posted: 1 decade ago 2011年4月8日 GMT+2 21:55
Hi Ivar,
Thanks for your reply. I'm sorry I missed out another boundary condition which is
u(x1) = 0
I still didn't manage to define this system.
Please help. Thanks
Chin Kin
Hi Ivar, Thanks for your reply. I'm sorry I missed out another boundary condition which is u(x1) = 0 I still didn't manage to define this system. Please help. Thanks Best regards, Chin Kin
Posted: 1 decade ago 2011年4月8日 GMT+2 22:43
Well in the new V4 COMSOL is somewhat more restrictive (if I remember right from 3.5) I see that it enforces two "zero Flux", one on each side on the external boundaries, so if I decide arbitrary to set X1=0.75 for a test and let u0 scan from -1 to 1 you get a solution per u0, as well as an unique solution on the domain 2 because you have the zero flux on the right boundary (if not defining something else).
But I'm not sure I got the full story here ;)
If you change the mesh from extremely coarse to extremely fine, you will see that the domain 2 has an unique solution for any u0, to the numerical precision via the relative mesh quality
Hi Well in the new V4 COMSOL is somewhat more restrictive (if I remember right from 3.5) I see that it enforces two "zero Flux", one on each side on the external boundaries, so if I decide arbitrary to set X1=0.75 for a test and let u0 scan from -1 to 1 you get a solution per u0, as well as an unique solution on the domain 2 because you have the zero flux on the right boundary (if not defining something else). But I'm not sure I got the full story here ;) If you change the mesh from extremely coarse to extremely fine, you will see that the domain 2 has an unique solution for any u0, to the numerical precision via the relative mesh quality -- Good luck Ivar
